Lost Spark
  • Lost Spark
    Hi, I have a pair of 2001 200hp HPDIs on my 28 foot boat. The port motor is not running properly. It appears that it is not generating a spark in cylinder number 1. the motor will start, and run at 400-500 rpm and usually stall within a minute.
    I pulled all the plugs and they all looked similar except #1 which was wet with fuel and clean.
    I changed all plugs with new - no change
    I changed coil #1 and coil #3 (since #3 shouldn't make a difference at idle) - no change
    I confirmed no spark with a spark tester
    I checked pulser coil - 310 - 316 ohms on all 6 wires
    whats next? should I swap ECU from port to stbd motor? Or is there another more obvious thing I should check?
    Thanks for your input.
    Check the pulser cool to verify that it is not grounded. Or connected to any other coil.
      Thanks for the reply. Could you explain how I would do that
        Does it have spark on #1 in gear?
          No spark in gear although the RPMs go up to 600 because the #3and #2 cylinders kick in.
