Twin F150s, (2008 & 2010)
I was de-winterizing both yesterday, new fuel/water separators, oil, etc. and checked both with new YDS. Everything was normal and both engines ran great, just as they did when I put them up last winter.
I did notice one thing I hadn't before, on one engine (2008) the fuel bowl, while idling, would drain down to half way, about even with the bottom of the filter. I could then pump it back up with the bulb and it would hold at full for a little while (about a minute) then go back down to half way.
The engine runs smooth and has never given me any problems except for a slight shake at idle that the other engine doesn't do. I was thinking the shaking could have been caused by maybe it needing to be synched & linked better, but now I'm thinking maybe the fuel system is sucking air somewhere and at higher speeds the air suction is overcome and it runs ok.
The other engine's fuel bowl stays full allways at idle, and it appears to have a small white check valve before the fuel bowl where as the other doesn't.
Anybody else ever have this problem? Why is one one way and not like the other? Or is the one that stays full in the wrong? I am awaiting new filters for the bowls maybe that's all it is.
I think I will start checking fuel lines on that side today.
Any thoughts appreciated.
UPDATE:
I swapped fuel lines (at the primer bulbs) and the 2008 still runs half full at the bowl so I wouldn't think it is anything from the tank through the primer bulbs.
I am probably just being a little paranoid about the differences since they both run great, but I just don't want a potential problem sneaking up on me 15 miles off shore (of course that's the beauty of twin engines ...right? lol)
Things will probably match (one way or another) after I change the filters.
I bought the boat new (it actually belonged to the owner of the boat manufacturer but was never titled) but the engines had 90 hrs on them. They claim to have done a 100 hr. service on them but I doubt they did anything more than change the oil. Anyway these filters look pretty dark so I thought it is about time for me to change them. I have always changed the fuel/water separators every season along with all the oils etc. Luckily I can find no trace of water anywhere (nothing in the separators or VST tank or fuel bowl) and the gas looks real clean out of the VST.
Will a pair of channel locks work ok on the bowls or should I take them off and do the freezer thing I have been reading about?
Thanks for any help guys.
UPDATE:
