Will this motor output NMEA 2k ?
  • Will this motor output NMEA 2k ?
    2005 Yamaha f150 txrd
    The motor has a 63p-31 ECU and the NMEA Harness
    From the reading that I have done the 63p-30 does not output NMEA but anything above 63p-32 does.. There is never a mention of the 63p-31
    I won't be able to mount the motor for a month or so and want to start ordering anything I need.
    Thanks..
    I think you will find that there is at least "some" NMEA 2000 output -
    which may - or may not - work correctly with what you want to display it on.
    My personal experience has been that Garmin products won't work with it -
    but other brands might.
    As far as Yamaha is concerned,
    the change from -31 to -32 was made "to accommodate to Command Link":
      I have a Simrad IS42 & 2 Raymrine Axiom's on a network.. I guess I will have to wait and see what I get! If I have to I will get a used ECU but hope I don't have to.
      Thanks.
