A mate of mine has a Yamaha 70 hp four stroke and wants to be able to display engine and fuel data on his HDS Live. There is no nmea 2000 backbone fitted to the boat but he does have 2 Yamaha CY8 Multi Function gauges. So my question is what is required to connect the Yamaha to a nmea backbone is there a loom to go from the back of the gauges or direct from the engine?
Here is a bit of information some one sent me but I need more information if possible
it is not necessary to connect to the engine though, you can use the 6Y8 LAN Hub behind the dash which the gauges run into....There are 2 ways to do this...
Navico NMEA2000 Starter Kit
Navico Yamha Interface Cable
or.....
Genuine Yamaha Gateway (Highly recommended)
Yamaha LAN Cable
NMEA2000 drop cable
The photos show the unit that the gauges plug into with 2 unused sockets (Device and Bus) that have covers over them is this the LAN hub and are these unused sockets used for the connections?
or.....
Yamaha LAN Cable
NMEA2000 drop cable
