identify this part?
  • identify this part?
    I recently changed the two thermostats on my yamaha F250TXR. The next day I found this part that seems to be some airt of gasket on my deck. Can anyone id this part and tell me where the heck it goes? I would hate to breakdown the engine again to attempt to figure it out.
    I hope someone can identify it.
    Looks to me to be an intake manifold gasket.
    Item 13 or 16 in this illustration:
    2006 and Later F250TUR Yamaha Outboard INTAKE 1 Diagram and Parts
      Thanks, you are correct. I showed the part to a shop that sells yamaha parts and the guy behind the counter was adamant that it was not #13. I guess he is wrong. I just removed the intake and one gasket was missing.
      I really appreciate your help.
      Andrew
        Glad you found the problem. Not good for the motor to be run with a missing gasket.
        Why was the intake manifold removed by the way?
          I changed the thermostats. The only way to access the starboard thermostat is to removed the starboard intake manifold. Unless I overlooked a n easier way?
            you definatly overlooked an esier way.
            glad ya caught it.
            only thing you may have noticed would be a slight increase in idle speed, possibly a MAP code, then a burned valve.
              Thanks for the feedback. Glad that I found it, a burnt valve sounds like a pricey fix.
              I would like to know an easier way to get to the starboard thermostat for next time that I have to change it. Thanks.
