I have a 2005 F225 tilt/trim unit I'm in the process of rebuilding. It had 7,000 hours on it (commercial guy) and operated fine, but when I opened it, it was just filthy. So I stripped it down completely. Removed all the rams, gear pump and the pipe on the top. Flushed it all out in a parts cleaner and replaced all the orings/seals etc. I have done many units this way with no issue.
I was testing it out and it seems off. It would go up on its own, but when going down the larger tilt would go down perfectly, but once it hit the trim rams it would just STOP. It was like the motor bogged down and just wouldn't move, like there was too much load on the motor. I could put a battery charger on the battery I was using and crank it up to starting 200amp and it would move it, but still very bogged down (motor didn't get hot). If I released the manual release screw...it would actually work again and pull the trim rams down without any force, but I could push them down as well. Once they were all the way down again, if I closed the manual release, it would bog the motor down again and it wouldn't run.
I took the motor off, and turned the "down-release" screw half a turn out so it would be "looser" and ran it up and down again. This time the rams would pull in by themselves and the motor would continue to run after the rams were full retracted...which is what it should do.
The motor seems to be running slightly different than what I'm used to once it gets to the trim rams, but it's working as it should (and without weight of the motor on it). Anybody else experience anything like this?
And I did also try to use another gear pump that I know was in good working order as well, same thing.
It is bled and everything is good otherwise.
