Why is the non-oil injection commercial motor rated 5hp less?
1990 85hp vs 90hp
C does not not denote commercial. If it stands for anything it stands for Cheaper.
Are you comparing a 1990 CV85ETLD to a 1990 90ETLD? CV stood for Customer Value. Not using oil injection it was cheaper to produce and sell. I think they simply dropped the V along the way.
Different block, different CDI assembly, different carburetors, etc., it would stand to reason that the HP output is not the same.
Originally posted by ausnoelm View PostThe CV model also came standard with an alloy prop instead of stainless, and most did not have a trim switch on the motor as well as the throttle, it was just an attempt to offer a cheap motor by cutting all the "frills" off the 90.
depends on what boat you put the motor on as to which prop was needed for the motor to run at proper RPM at WOT
I did not think any motor came with a prop.
But it also made sense to come with a prop, because one needs to start somewhere, and I guess if the motor/boat combination was a bit “unusual” there might have been dealers that swapped the prop at point of sale. Sadly otherwise the boat owner had to fathom it out themselves after purchase at their own additional cost.
ÂÂ
