I have seen on some models that there is a filter underneath (bottom) the main oil resevoir.My resevoir does not appear to ever have been removed for this service.Before I tackle the mounting bracket which also looks to have never been touched,Does anyone know what models/years have this filter??? My Clymer manual makes no mention of it.Thanks CC
2 stroke Oil filter 2000 200hp saltwater series 2 stroke
There is a strainer in the main motor mounted tank and a strainer on the boat mounted remote tank. Main oil tank is on the motor.
Yamaha introduced outboard motors in the USA in 1984. Yep, the remote oil tank had a strainer on it even back then.
Item 5 in this illustration. https://www.boats.net/catalog/yamaha...ialln/oil-tank
Update......The inline filter/strainer is UNDER the reservoir.The reservoir must be removed from the housing compartment and placed on its side to access the filter.This filter change was waaaay tougher to do then it should have been.Im sure Yamaha had a good reason to put the filter UNDER the reservoir however it made the change out more cumbersome.An empty reservoir makes it easier.Mine was full.Charlie
Â
