Hi there. Recently bought a boat with a Yamaha 40HP 2 stroke outboard.
The sticker for the engine number is missing but I believe the motors a 2003 VETO. I am hoping someone can explain the engine guardian mode and what triggers it as the yellow light is stuck on and the revs are cut to around 2000RPM.
Cleaned out the carbs and found the enrichment solenoid and red switch were both seized so changed them out. Lifted the float sensor in the tank and tested the low oil buzzer with everything checking out on the digital gauge on the dash. Visually inspected both temp sensors and chased wires for breaks or disconnected plugs and everything seems fine. The engine is in brilliant condition with little to no corrosion anywhere.
If anyone can shed some light on this system or can tell me what resistance the float and temp sensors are supposed to run would be a massive help. Cheers
