what causes the lower crank seal to start leaking on a 1992 c85 tlrq Yamaha ? would it suck air and run lean causing power head failure ? noticed oil running down the front of the mid section. not clean oil , appears to be mixed fuel residue . this is not an oil injected engine . does the engine need to be dismantled to replace any seals or gaskets? split the case or what have you? thanks in advance for all info given mike
lower crank seal on a 92 c85 hp
Originally posted by scarab30/200 View Postappears to be good except for the oil running down the front of the midsection
ÂÂ
