9.9hp 4stroke 2006 runs fine until the cowling goes on
  • 9.9hp 4stroke 2006 runs fine until the cowling goes on
    Hello forum, new guy here.
    I have a pair of 9.9 4strokes to power my sailing cat . I recently replaced float needle & mix screw, ran fine for a few hours,but now it runs fine until the cowling goes on, then it struggles & stalls after 30 secs or so. I assume a lack of air getting in, I’ve checked the cowling vents, even swapped cowlings, I’ve checked the intake mesh, I’ve checked that the cowling isn’t pinching a wire. In frustration in I drilled a 20mm hole in the top. It still isn’t happy unless the cowling is off. Any help appreciated
    Maybe an exhaust leak inside the cowling....
      maybe an exhaust leak cutting down the O2 under the cowling,
      but I am not sure exactly where that would be a a 4 stroke
        Thankyou, I went around the head bolts, one of them allowed a 1/4 turn, the rest a tiny bit, warmed the motor & put the cowling on, running fine now, taped up the hole I drilled, sweet as a nut, fingers crossed, thanks again. Robert graham & 99yam40. Gotta love a simple logical solution
