Is there any way to open up the butterfly valve further on the throttle body? My mechanic says it's at about 80% and he'd like to see it open to 90% if possible. If I open it up more will it provide more power?
2006 F225 butter fly valve adjustment question
I believe he was using his eyes, not the laptop. He used percentages instead of degrees. He said like to see it vertical if possible. I've sent him a text to explain it to me a little more.
Can it be adjusted or not?
only by the link and sync.
he most likely was reading the laptop, it gives percent of throttle opening.
80-90% is normal on the laptop.
the information is calculated by the ECU based on the tps feedback.
ÂÂÂÂÂ
