F150 water pressure
  • F150 water pressure
    I have an 05 F150 on a tunnel hull bay boat with jackplate. When jacked all the way up and trimmed up to run shallow i lose water pressure. I heard there are small scoops that can be added to the intake screens to aleviate this. Where can I get me a pair? Is there anything else I can do? Thanks
    barbless,
    Go over to another forum where I am a member - www.maverickboats.com and do a search on "low water pickup". I just did that and there is a lot of discussion on the low water add-ons - mostly causing a lot of problems with picking up debris and clogging up water jackets and eating up water pumps.
    You might try dropping the motor down just enough on the jackplate to regain water pressure after you get up on plane.
    Ken K
