I took my boat out Saturday and it was running fine at first then started bogging down could only get 3200 RPM. So I took it out of the water and pulled the VST tank and check and cleaned the filter, also I changed the F filter. then I pulled the injectors and cleaned them out. Put the Boat back in the water and it ran fine other then idling around 1200 RPm,
So I figure I lest a Vacuum hose or something off. I checked and double checked but everything was hooked up.
So I notice when I put my finger over the idle valve inlet it would idle down to 6000, So I pulled the valve started the engine and it appear to operated as I think it should
So this is were Iam at. Any idea?
