My 2006 Yami 150 is making a knocking noise when it is in forward idle or reverse idle. neutral idle, forward and reverse are smooth. I took off the prop and there is no noise. Return prop and the noise starts. Makes noise in water or on land. Sometimes it doesn't make the noise. I have video but can't upload to this forum. Any ideas?
2006 Yamaha 150 XTR knocking noise.
On some engines, you can get that annoying knock if when the last WP was installed, the driveshaft was NOT PULLED UP FULLY, and the retainer installed.
That set up simply keeps the shaft from going up and down slightly-knocking.. I suspect that may be your noise-Won't hurt anything..
If it is, to repair is to R&R the LU, pull up on the drive shaft and push that retainer back down(while pulling up on the drive shaft)
Originally posted by TownsendsFJR1300 View PostOn some engines, you can get that annoying knock if when the last WP was installed, the driveshaft was NOT PULLED UP FULLY, and the retainer installed.
Thank you for your replies. It's been about 500 hours since the waterpump was replaced by a dealer. The sound just started a few weeks ago. I do a lot of slow *****ing with live bait, so I'd like to get it fixed. I'm going to take it to the Yamaha dealer for service. I'll let you know what happens. I really appreciate your help. It's good to go in with a little knowledge.
Originally posted by fishcrazyinfo View PostThank you for your replies. It's been about 500 hours since the waterpump was replaced by a dealer. The sound just started a few weeks ago. I do a lot of slow *****ing with live bait, so I'd like to get it fixed. I'm going to take it to the Yamaha dealer for service. I'll let you know what happens. I really appreciate your help. It's good to go in with a little knowledge.
ÂÂ
