I have been battling a stalling out problem on my Yamaha 4 stroke 225 HP engine for years now. I'm at the end of my rope. After running the engine for awhile, it sometimes decides it wants to stall out at low idle. If I squeeze the primer bulb, it will usually restart right way and will run until it decides it wants to stall again. There is no pattern whatsoever to what is going on. Also lately when I squeeze the primer bulb, it stays depressed for an inordinate amount of time. I have replaced both pumps in the engine, all fuel senders, and a host of other parts. I even went as far to install a separate pump to the fuel line just before the primer bulb so there would always be fuel at the ready.
I have put thousands of dollars in to rectify this problem on an otherwise perfectly running engine.
Can Anyone Help Me? Again I'm at the end of my rope and quite discouraged.
