Yamaha 2003 225hp not running
  • Yamaha 2003 225hp not running
    Model LF225TXRB Cranks ok but will not run while in normal start position. Will start and run when advancing throttle while in neutral. While running, engine runs rough. Replaced plugs What next to check? Other motor runs ok. Thanks
    next step ,actually should have been the first step, test leakdown and spark.
    then go fix the fuel system.
    a compression test,while not as accurate or useful as a leak down test can be done.
      check compression, spark and timing if all is well look for fuel problems.
      Fuel pressures, injectors testing, filters, water in fuel etc.
      Dang Rod snuck in there before me
        yamaha 2003 225hp not running
        Thanks for your input. Noticed plugs all black. Looks like my mechanic is the next step. Will advise outcome
