Have no spark at idle at cyl nr 2, but somethimes intermittent spark when throttling up. Coils, plugs and sparkplugwires checked out. Need advice about what to check, can I measure DVA-out from cdi-box to coil ? (what value)? All advice will be thankfully recieved. Engine is a 75 hp 3 cyl 2stroke. (1999 mod)
No spark at cyl no.2 75hp 1999 mod
model # would be nice as you are not in the states not sure what would match on this side of the world.
Yamaha service manual will have all the procedures and specs for testing. Your local Yamaha dealer should be able to help get a manual for your motor
This might give some info, but not sure it will be correct for you motor.
There is Yamaha info way on down about page 110.
http://issuu.com/cdielectronics/docs...owFlipBtn=trueLast edited by 99yam40; 01-23-2015, 07:36 PM.
Originally posted by 99yam40 View Postmodel # would be nice as you are not in the states not sure what would match on this side of the world.
CDI Electronics Practical Outboard Ignition Troubleshooting
Thanks, will do all the measure with a multimeter and a DVA-adapter and reply when done.(tomorrow)ALWAYS open fore new knowledge
ÂÂÂ
