I have had an intermittent problem with my 2002 F115 when on hot days ( and usually in the afternoon ) after I restart the and take off after about 15-20 seconds the engine looses power. When I pull the throttle back it sometimes stalls or runs rough for a bit and then it comes good.
I have done some searching and it appears that earlier models had this problem and it is caused by the fuel heating up and venting into the intake causing a rich mixture.
Apparently there is a "kit" available but it is expensive - Is there a part number for it ? How long to instal it ?
Also people say to let the engine idle for a bit when you slow down after running hard. Any other "fixes" for this issue ?
I have serviced the whole fuel system including the injectors and VST.
Thanks JON
Thanks JON
