I have a 1997 C25 MLH. I have the factory service manual. I have cleaned and rebuilt the carb. New plugs. Been decarbonized. Clean fuel at proper mix.
I have a miss from low idle (1100 per manual) through roughly 2500, then it smoothes out through WOT
I cannot get the timing in specification using a timing light. Full retarded timing is 6 ATDC +-2. If I have the bracket adjusted all the way to retard, it won't go below 4. I know that is within the lowest spec tolerance, but then I cannot get 22BTDC WOT spec.
I have tested the pulser coil, charge coil, and primary and secondary coil resistance. All are outside of what the factory manual specifies. I verified the resistance readings with two different DMM's
I find it hard to believe that every part of my ignition system is bad. I have not tested the CDI box yet.
Also, the manual shows two pulsers and two ignition coils, I only have one of each, so is there a possibility the factory manual is wrong? Did they change something mid year?
Thanks for your help!
