I have a 1999 225 trlrx yamaha with no gauge package.The oil pump will not pump oil from the sub tank unless I use the emergency switch. Changed oil pump, changed oil filter , cleaned sub tank and checked oil level sensor on motor. Continuity checked good. my question? can the oil level switch be bad with the continuity checking good. I have read post relating to oil problems any help would be greatly appricatied.
Oil problem
Oil problem
The switch according to the yamaha manual is within specifications. The wiring harness look good,haven't done a continuity test on wiring harness.
Oil problem
ÂÂÂÂÂÂÂÂ
