I accidentally crossed battery connections, only for a nano second. I have lost all power. Is there a reset under the engine cowling?
F200XB accidently crossed battery polarity, is there a reset.
Likely blew the main fuse. Look on the side of the engine(or owners manual) to find it.
Posting a YEAR to your engine would help to look up parts/location of fuses, etc..
.https://www.boats.net/catalog/yamaha...2/electrical-1Last edited by TownsendsFJR1300; 06-15-2020, 02:48 PM.Scott
Actually it is a 60 amp, 58 VDC fuse, It is a plug-in, female, yellow. & low profile The only one I can find is 32 VDC (which I cannot understand why the voltage difference). I cannot find the fuses on the FL200XB, 2013 engine. Is it dependant on the F200XB, 2017?
60A_LowProfile_JCase_Fuse_46304_f.pngLast edited by TAEZZARS; 06-17-2020, 05:06 PM.
very interesting that Yamaha changed the fuse box / fuses over those years
the 60A fuse for the 2017 can be obtained right here at boats.net
https://www.boats.net/product/yamaha/6CB-82151-40-00
as can the 60A fuse for the 2013
https://www.boats.net/product/yamaha/6P2-82151-00-00
(although when you finally find the fuse box on the 2013,
there is a spare 60A stored behind the fusebox cover)
Fairdeal, I appreciate the info : very interesting that Yamaha changed the fuse box / fuses over those years
However when I C&P into gaagle, it shows the fuse with the screw base instead of a female plug in. That was all I could find & it is why I posted the photo of the fuse.
Could you try again, please?
Hopefully my last question on this. I found a spare fuse in the F200XB, thank you Yamaha. That proved the 2013 FL200XB to have it's main fuse blown too.
The engines are tilted up, making it hard to view the fuse box on the FL200XB. It seems that the fuse cover may come off with a slight pry, but I don't want to damage anything. Can you advise the procedure for accessing the fuses in the FL200XB? Thanks
Originally posted by TAEZZARS View PostIt seems that the fuse cover may come off with a slight pry, but I don't want to damage anything. Can you advise the procedure for accessing the fuses in the FL200XB? Thanks
If the cover looks like this (I circled in blue the tab), simply push the upper tab down slightly and the cover should tilt out and then off..
Â
