Good day,
Need advice on how to slacken the nut/cap to replace seal on tilt. I have the four-studded tool but being as the boat is kept in salt water, the cap is extremely tight. Any advice on how I might slacken it? Is it advised to use any sort of heat to loosen it, as this is hydraulic and there is already fluid on the part?
Thank you...any advice is appreciated.
Blake
Blake
