I have a 2000 Yamaha C50 with a trim/tilt issue. The motor tilts up and down fine, however when tilted up it slowly bleeds downward on its own. There are no external leaks at all. Is there an internal check valve or something I can replace?
'00 C50 trim/tilt bleed down
Is this happening only when the motor is tilted up and not being used? Or, does this also happen while the motor is being used such that you have to trim it back up from time to time?
If it only happens when the motor is not being used then I would leave the unit alone and use the tilt lock device to keep the motor in the up position. Now if it happens while the motor is in use then you are going to want to find and fix the problem.
More than likely a check valve is not checking as it should or perhaps an internal seal is leaking. Finding the offending culprit can be a bitch. There is a whole lot going on inside of the particularly trim and tilt unit used on your model. While looking for and fixing one thing some other problems are apt to appear. That is why I would leave it alone if the problem occurs only while the motor is not being used.
Take a look at the internal workings of your unit. 2001 C50TLRZ Yamaha Outboard POWER TRIM TILT ASSY Diagram and Parts
Your call.
Hopefully Rodbolt will give some of the different valves to look into if the manual one is not the problem
Could be one of the pressure relief check balls that open when you hit something to allow motor to come up, and I am sure there are other valves also.
How did this start?
Anything happen to motor or something you did to it?Last edited by 99yam40; 12-28-2014, 02:39 PM.
Originally posted by 99yam40 View PostHopefully Rodbolt will give some of the different valves to look into if the manual one is not the problem
How did this start?
my advice???
take it to a dealership with a master tech.
that is one of the most difficult units ever designed to play with.
certain special tools are MANDATORY.
simply cannot do the job without them.
my guess is the trim ,tilt or memory orings are leaking.
If you have not noticed before, Yamaha does not recommend using that lock for trailing, it can bend things bouncing down the road when hitting things.
Only for servicing the motor to keep the motor from coming down on person while working under it
Originally posted by 99yam40 View PostIf you have not noticed before, Yamaha does not recommend using that lock for trailing, it can bend things bouncing down the road when hitting things.
Also thanks everyone for the advice and suggestions!
Originally posted by Stikman79 View PostI never use the tilt lock for trailering. I use a product called the Transom Saver that extends from lower unit to my trailer frame. I'm saying I support the weight of my motor while trailering so none of the motor weight is even on the trim and tilt while bouncing down the hi way...
ÂÂÂÂ
