The back story :
I purchased a 2006 Yamaha f115 four stroke which was a tiller model that I swapped over and am making into a front/remote control unit. After purchased all wiring, controls, etc I’ve encountered issues with the tach gauge.
The tach gauge shows full trim with the top bar blinking. Despite playing with the trim sender at the engine I can’t get that gauge to change. In addition to the blinking trim it also intermittently shows the water in fuel warning light.
I checked ohm output at the trim sender and it seems to be working. Started at about 94 ohms down to 0. I checked ohms at the connection behind the tach gauge and the white/red wire has a proper ohm output also but only when I ground it to the boat( if that makes sense ).
im not a technician by any means. Any thoughts out there from anyone ?
