Good morning, I just joined the forum and in search of some knowledge. We were motoring along and the F225 just shut-off, initially I thought I fish trap line and fouled the prop but that wasn't the case. An attempt to restart the engine was unsuccessful, the engine will turn but will not start. I'm going to look at the fuses and relay to see if they are good and will check the switches that I can. Any other suggestions to consider? Thanks in advance for any help.
F225 Question
Originally posted by fairdeal View Post'fuel' is an obvious question -
what do you learn when you pump the primer bulb?
what year/model F225 ?
take off the flywheel cover
and check that the cam gears/timing belt are still there
The 3.3 liter F225TXR(X) series of models is a non-interference motor. There will be no damage to valves or pistons as a result of the crank shaft being out of time with the cam shafts.
Presumption being that you have a 3.3 liter F225. Must be top secret intel.Last edited by boscoe99; 05-20-2020, 10:54 AM.
Originally posted by boscoe99 View PostThe 3.3 liter F225TXR(X) series of models is a non-interference motor. There will be no damage to valves or pistons as a result of the crank shaft being out of time with the cam shafts.
yes, a standard 3-bolt "harmonic balancer & steering wheel puller"
should handle the job
the bolts are of course metric - M8 - 1.25
be prepared - some flywheels do not come off easily -
you may need extra washers under the bolt heads -
maybe even high tensile bolts
if you have an air or electric impact wrench,
that is excellent for drawing the puller down
ÂÂ
