I am in the process of installing a water pressure gauge and sending unit on my 2005 f115. When I ordered the part I recieved the sending unit for the temp gauge. So I have decided instead of sending it back why not just get the gauge to even out my console.
Question is: Where does the sending unit go for the temp? Thanks to Hamfisted I know where the water pressure sender goes but not the temp. Also should I coat the threads of the senders with high temp silicone or what do you recommend?
Lastly I replaced the pressure control valve as recommended with the new part. The old one had x shaped plastic pieces sticking out from both sides of the flat part that seated against the grommet. The new one had on one side x which I put into the spring and the other side is rounded, which I seated against the grommet. Just wanted to know if this was correct, because I did not know if it woud stay in place that way.
Thanks again!
Thanks again!
