Hi everyone,
I have looked through dozens of pages of this forum trying to find a solution to my outboard problems. I have a 1988 PRO50LG 50hp, tiller handle model outboard, I have had this motor for just over a year now. I had some problems with it last fall that was most likely carb related as it would run rough intermittently. I replaced the things i could (fuel lines, fuel filter, fuel pump, spark plugs) and then I took it to a marine shop local to me (Lacrosse WI) and had them go through the motor and re build the carbs, so they are clean for sure. They also check compression and timing and spark and said everything checks out good. Now the motor runs like a top, after I get it started. Before i took it in it started kinda hard on a cold start but nothing out of what i consider ordinary. 2-3 times turning the key with the choke out and it would pop off.
However now it starts cold extremely hard, after it fires it will run just fine and start back up after i shut it off by just bumping the key. I cant afford to take it back to the shop and have this dealt with as i already got soaked for almost $1000 dollars the last time. Would any of you have any suggestions as to how to make this motor start easier? i would greatly appreciate it.
Thanks,
Jesse
Thanks,
Jesse
