1990 200 yamaha propellar shaft seal leaking. have 5lb. mac tools slide hammer. need propellar shaft puller (adapter) beleive part# to be YB-6335.any one know where i could aquire one? thanks john
yamaha propeller shaft puller
Don't forget the acetylene torch ! If it's been used in saltwater that carrier will be welded in there and need heat to come out. Heat up the outside gearcase to get it to expand a little to free up the carrier. You'll have to repaint the torched areas later. Grease the inner case contact area with some teflon grease before reassembling it. Good luck.
Mike....... Miami, FL
ÂÂÂÂÂ
