2003 Yamaha f25 electro-thermal ram (cold start) Question
  • 2003 Yamaha f25 electro-thermal ram (cold start) Question
    I have a 2003 f25 tiller ,I recently had the carb off to clean it out .i forgot to
    Mark the wires that I disconnected from the motor to the sensor.the
    Problem I'm running into is..the two wires on the sensor are yellow,
    There are 2 plugs that come from the motor,the plugs consist of two wires,
    In each plug .each plug has a solid yellow wire and a yellow with black stripe wire.does it matter which goes into which? And if so how do I find out ?
    Any input would be greatly appreciated !
    Thanks chris
    It does not matter which plugs go into which connectors.
      I thought so but wasn't sure,thanks for the info.
