Hello my concern(mari****) has all here is, having to notice that I is nourishing was in decompression to séver, the vent(blowhole) being opened but an insect had blocked the circuit of air by finding refuge there. I open the reservoir clean the vent(blowhole) I redoes a complement to gasoline(essence) and at the time of leaving(restarting) the engine gives the impression of tour on three cylinders
hmy:
Of return I decide to change candles without results(profits) cleaning of the reversoir more the nada caul:S complete change of the feeder pipe of gasoline(essence) more the pear:toujours similar:: new D-leaks out has to settle, new fast join always nothing the same symptom new coils of no more advanced ignition:unsure:
Cleanings of carbu the gigleur main more that of the pump of resumption:même the engine is one 60 cv YamahaYamaha 4 times(weathers) has carbu of 2002: F60AETL, rise on a bombard to explore 500
In navigation(browsing) the engine does not take any more its maxi tours(towers,ballots) on 2600 trs and vibrates more that abnormal putting has a share a carbu regulation more a synchronization I am has court of ideas:RB: +) if mechanics or if you had you the same problem I am interested for any new tracks(runways) I wish you has all well winds and good day:: r-
