06 2 stroke 70tlr having issues on cold start. I went ahead and did a test on cold start with the emergency start tab in the on position and it started with no issues. So I know something with the starting assembly is the cause or I think. I tested for voltage going to the starter plunger valve which I was getting only 6 volts and also thought it was weird that where that blue wire from the plunger is connected goes in connection straight to the lighting coil and not out the reg/rectifier side but maybe that's normal. Just trying to make sure that this information seems legit before I dig into the starter assembly and clean that out. Once she is running you can turn of and on with no problems just would love to get a better cold start up. if anyone knows what the voltage should be to power up the starter plunger please let me know.
06 70tlr 2 stroke cold start issues
what were you measuring the voltage with, and what did you have it set to?
the service manual should have a procedure for checking that voltage
good chance it calls for peak voltage which should require a special voltmeter or an DVA adapter.
the voltage is only needed while running to turn off the extra fuel once the motor has warned up.
so apparently you have a problem with something plugged up not letting the fuel flow when cold
Thanks guys. Yea I was using an dmm rms meter but I think you are correct and I am gonna look for something that's plugging fuel up.
ÂÂÂÂÂÂÂÂÂ
