Hi, we have a 1999 70hp injected 2 stroke. She runs absolutely fine under power and starts well. When cold and at idle she excessively smokes and eventually goes away and smokes like a typical 2 stroke. If we shut down for around 1/2 hour and start up again, excessive smoke again. Where am I best to start diagnosing?
We have just bought it and am unaware of the oil type previous owner was running, so planning to drain oil and start with Yamalube, is this the best to use?
I have read that there are two 'O' rings at the back of the oil pump which could be the issue also, so that could be next. How easy is it to get to these?
What are the most common problem areas that I should look at? Any suggestions would be greatly appreciated.
Thanks.
Thanks.
