Hi guys, my neighbor has a 2002 f 115txra, , it will not start after running to regular temp, it will crank,but not start, let it sit for 15 minutes ( cover off to speed cooling ) starts , runs fine. Also, new tach installed recently, and now works sporadically ( may be red herring) , new voltage regulator ,and various fuel system components have been replaced according to neighbor, any help would be appreciated, if further detail is needed I will ask neighbor for specifics , I am leaning towards vst issue , thanks again Eric
F115txra - will not restart warm
Originally posted by rodbolt17 View Postwhen you turn the motor OFF, do you hear a rattling sound?
when you turn the key ON do you hear the fuel pump whine about 3 seconds?
I have that same motor and Yes I think I hear a rattling sound when I turn mine off...what is that?2002 19ft. Baystealth 1888 with Yamaha F115 (4 stroke)
2002 15ft Alumacraft with 25 Yamaha 4 stroke
Originally posted by rodbolt17 View Postthat rattle is the ISC valve resetting to 100% in anticipation of the next start cycle.
its part of why EFI motors start at a faster RPM than idle.
My Ford truck does the same. I hate it.
rodbolt,
What is the tapping like noise when starting the f50/f60/f70?
almost sounds gulping down a beerLast edited by greasyshaft; 09-14-2014, 06:20 AM.
Â
