Ok, I give... this bleeding of the power trim is killing me!
I have replace all the fluid in the trim unit, with the caps removed I filled the trim and tilt unit and replaced the caps.
I had to replace the O-rings between the motor and the unit itself to repair a leak (Seems like something major for a mostly freshwater 130 hr Engine), the rest is a long story, but be very careful with the check valve ball.
So here is the issue:
I have the unit FULL of fluid and bled (sort of) I can still hear air gurgling at certain points in its motion when I run the motor. The engine WILL go all the way up... BUT WILL NOT go down under power. I have to open the bypass to get the engine to drop.
Once in the full down position I can get the trim (range only) to go up and its ****ey to come back down. Once in the TILT range, it will no longer return to DOWN motion. I have to use to release to lower the engine then it will raise to full range, but again will not lower.
I have lifted the motor manually with the bypass open several times (this is when I wish I had 2 boys instead of 2 girls and the kids next door just left for the ARMY) NOT an easy lift by yourself.
So it's been sitting in the down position for a day now resting so maybe any air I have introduced by using the motor may purge itself.
Any suggestions before I go out there and practice deadlifting the YAMAHA 115?
