Rodbolt,
I am trying to map out what I will call the vapor recovery system in an F225 as the motor was modified by O2003-020. Unfortunately, Yamaha never documented this in any place that I know of.
Please take at the illustration and let me know if you agree or disagree.
Also, the connection the air intake silencer has got me confused. When the VST vents into the recovery system what is to prevent the fuel fumes from simply going to the silencer via the orifice air vent instead of flowing to the charcoal cannister via the pressure relief valve? This assumes the vent is really just a vent and not something more complex.
As you know, Yamaha will call a pressure relief valve a check valve. Two totally separate parts with different functions in my mind.
