fuel is not flowing into throat of #2, removing plug on bottom of bowl shows fuel, can see spray into #1 and #3 while running sluggishly on plane with carb cover off. have ordered a SELOC manual, am pretty good at mechanical stuff, thinking a jet is clogged. Can anyone give me any advice to move forward - is it a complicated job?
2005 40hp 2 stroke no fuel to #2 carb
Running full power now. Idle is a little rough. Will run SeaFoam though the next couple tanks. Seloc manual helped a little in finding how to get to the main jet where I found some crud build up. O rings for gaskets were unexpected and easy to deal with. I was pretty easy. Thanks for the help.
Â
