anybody know anything about how this thing is supposed to function or be installed? Does it just rest on top or is it glued down with sealant or something???
oil seal cover in lower unit 2002 F115
Originally posted by greasyshaft View PostGet the dolphins to sort it I hear they are good with engines!! They try to tell you this by swimming near your bow but us silly humans never take the signs
Looks like you have been drinking some of the home made stuff
Originally posted by rodbolt17 View Postits actually trapped between the wear plate and the bearing housing.
no sealant.
Thanks Rod!
I was changing the wearplate and the wide section of the rubber seal was pealing up a bit and when I messed with it it just kinda popped out. I went ahead and ordered a new one. maybe not needed but for $10 it was peace of mind.
Also broke a grease zerk. Are they just standard pick em up at the hardware store size?Last edited by Pas Bon F115; 09-06-2014, 11:39 AM.2002 19ft. Baystealth 1888 with Yamaha F115 (4 stroke)
2002 15ft Alumacraft with 25 Yamaha 4 stroke
Also broke a grease zerk. Are they just standard pick em up at the hardware store size?Scott
Originally posted by 99yam40 View PostI guess y'all are about the only ones that can do that legally
It's Happy Hour(s) down under! Guess the dolphins are talking too!Last edited by TownsendsFJR1300; 09-06-2014, 02:37 PM.Scott
Originally posted by TownsendsFJR1300 View PostI was able to get them at an auto parts store (metric thread). Bring you broken base down there to match up...
Thanks for all the comments and help!!2002 19ft. Baystealth 1888 with Yamaha F115 (4 stroke)
Originally posted by Pas Bon F115 View PostGot em at O'Reilly's bought an assortment pack for about $4. The other packs were like $8 for a pack 8 or so. I only needed one and got lucky that there were a couple in there that fit!
I got mine at Auto Zone (as I re-call). Drilled and tapped boat lift bolts, making them greasable with a grease gun vs pulling apart manually....Scott
ÂÂÂÂÂ
