Hate to start off with my first post asking for help, but got in over my head today when trying to replace the impeller on my 1985 Yamaha 90 HP. In trying to remove the lower unit one of the bolts snapped off. I managed to drill through the broken bolt enough that I could try a bolt extractor to remove the piece that was remaining. This also broke off. I managed to knock the part that broke off the extractor through what was left of the bolt. I ended up cutting threads for a 1/4" bolt in what was left of the bolt. I spray a lot of WD-40 up through the bolt before trying the extractor and it still wouldn't budge. Should I take it to a machine shop to see if they can remove it or is there something else I can try to get the remaining piece of the broken bolt. If I can get it out, is a 1/4" bolt plus the other 3 going to be sufficient to secure the lower unit. I've only had the boat out twice and it was overheating at low speed and very little water coming from the pee hole. Any help is greatly appreciated.
First Post, Need Help
heat is your friend, and use a good penetrating oil like Kroil or even pb blaster heat it hot, with an IR temp probe monitor the temp as to not melt your alum.
then use your easy out, with some time you should be able to get the broken bolt out. I do not advise using a 1/4" bolt replacement. If the threads get damaged you can use a helicoil or Loctite Form-A-Thread is a great product that you can use to repair the threads.
good luck
NEVER EVER EVER use an easy out.
DO use oxygen/acetylyne.
once they break the only good alternative is to simply drill and retap or drill and heli-coil.
usually stuck bolts are simply due to lack of maint.
An easy out is almost never easy. In my experience they only make stuff worse.
Folks don't want to do maintenance on a product that is operated infrequently, at high loads, usually on crap gasoline, in a very harsh environment, but then wonder why stuff goes wrong.
Maintenance is not a four letter word. The more maintenance that gets done the better the product turns out to be.
ÂÂÂÂÂ
