Trying to match the correct Prop to Boat/Motor
    Originally posted by Spartan811 View Post
    Thanks for the info - Boscoe99,
    I rechecked the Resister with the DVOM at
    the lowest setting, and now it readings
    are 1.2 ohms.
    Did you check the resistance in the leads?
    If not zero, subtract what is shown from your measurement.
      if it idles why bother with the resistor?
      its working or the pump would not run at speeds below 1500 or so.
      all it does is drop pump operating voltage to about 9V below 1500.
        are 1.2 ohms.
        But still not in range @ 0.53 - 0.57ohms
        would this be acceptable or replace?
        Thanks for your help 99yam40!
        Take the 2 meter leads and connect them together,
        look at what the resistance is reading and write it down.
        This is the lead resistance that you need to subtract from the measured resistance
