Is there anyway to increase horsepower on this 50HP engine to a 60HP model? Maybe changing the carb jets? Or anything else?
2004 Yamaha TLRC HP Increase?
Originally posted by ausnoelm View PostJust pull the choke half way out, that's about the same as adding bigger jets.
OP, this question is often asked, however rarely is there a practical solution to gain such an increase in power. So you might see some sarcasm in replies.
Originally posted by zenoahphobic View Post
Never ever seen choking add top end power. Can improve lean low end power that's why a choke is used to pull in more fuel in a cold engine.
But as noted, it takes more than just more gasoline to make more power.
