guys,
Ive got a 2001 Yamaha ox66 engine with a Showa tilt and trim. Im having an issue with the tilt mechinism not preventing the engine from being lifted when I accelerate or in reverse. It can even be lifted by hand when on the trailer. Using the tilt and trim from the switch works normally. Lifts completely and goes up and down all the way with no issue. I have bled the system and even replaced trim seals ( not tilt as that’s a much bigger project). Any thoughts on why the motor can move in that direction ? I have twins and the other does not do this.
So to clarify: the tilt and trim work properly but the tilt arm is not holding the motor down when force is applied to the motor in any fashion that would life the tilt rod out ( rapid acceleration or pulling up on the motor when it’s on the trailer).
Thanks!
Bulls-eye
Thanks!
Bulls-eye
