50 HP security power switch
  • 50 HP security power switch
    Hi,
    I recently bought a used 2009 Yamaha 50 HP, and the security power switch is not working.
    Could you please send me the schematic for this electric part?
    tks
    sounds like you have a stolen motor that you cannot start.
    A little more info may be needed
      What you are talking about? Y-COP?
      What makes you belive you have a problem?
      Yamaha that I know does not supply schematics
        by saying security power switch is not working, i meant the security device that turns off the motor in case of man over board. At the moment if i pull the security strap the motor keeps running.
          You may have a bad ground wiring or a bad switch.
          Ground the white wire and check if it stops.
          És tuga?
            thanks ALMETELO problem solved,
            It was indeed a bad grounding wiring. I've touched with the white wire on the motor structure and it stopped running.
            Also noticed that a metal pin was missing on the ignition switch. This pin should be the grounded link between the ignition switch and the motor structure.
            Sim! sou Tuga, Porto, Gaia
