We are patiently waiting for coil to come in as we think we may have a funky one. Have not done a full timing light test yet but the one plug loads up a bit.
The engine screams out of the hole up to about 4800rpm and then there is a loss of power and it runs pretty good about 4000-4200rpm. My buddy on this project says it reminds him of when he's had bad coils on previous engines...and says that one bad coil spoils the party pretty hard when it comes to outboards.
What else would you guys be checking?
We've got the carb sensor dialed in at 0.5v
linkages are tight
Fuel flow seems fine with new lines, filter housing, filters
Figured if CDI trigger was not producing enough voltage we'd see more violent issues with running.
What other fancy pants electromagnetic magic should we concern or does this sound like a coil issue to you?
linkages are tight
