F40 4stoke oil leak
  • F40 4stoke oil leak
    I have a 2006 F40 tlra that is leaking oil @ the powerhead. when I pull the dipstick oil is gushing out? when I idle for a long time oil from the crankcase breather is getting into the carbs?
    any ideas? I thought maybe the ccv is blocked or?
    If it comes out the dip stick it could be making oil. Does you oil smell like gasoline?
      I just checked & yes it does a little?
        how does fuel get into the crankcase past the cylinders? broken rings? I am not experiencing any loss of power except occasionally after extensive idling the engine smokes badly & chokes out. When I restart it's fine?
          You probarly have a defect thermostat, engine is running to cold and some gas comes in oil.Easy to replace
            thanx for the help! Guess I better do an oil change too!
              sounds like you need to be checking your oil more often also
