I am in possession of a 2005 carbureted 200 stroke that the previous owner ":disconnected" the oil injection. Everything on the oil injection system looks intact with the exception of the oil level switch for the oil tank located under the cowling.
I have at my disposal, a 2001 carbureted 130 2 stroke. When I look up the part numbers the switch part numbers have different pre-fixes, but the main body of part numbers is the same.
Are these two interchangeable? This is only for a test to see if the system is pumping. If the injection system works I want to continue to use the oil injection instead of pre-mixing.
Thanks to all for sharing their knowledge and wisdom
