I went to start the 150 saltwater series, turned the key and nothing. not a sound. i have a dual battery setup and it was only on 1 battery. battery tests good. key switch has a choke option and trying to start it a few more times using the choke got it started. after running for awhile, turning it off it started right back up. I would turn it off, let it sit and most times it would start. A few times when you turn the key nothing happens but after a few tries it starts. Battery switch set to either single battery or to both did not appear to have an impact on knowing if it would start or not. Also have a battery isolator in place.
This was going to be the second trip of the season. Last trip out it also did not start once but at the time I thought I did not turn the key far enough but now suspect this was also a problem then.
Did not have this problem last season.
Any suggestions on what to check. All connection look solid.
TIA
TIA
