40hp dead cylinder?
  • 40hp dead cylinder?
    I give up. At idle or mid throttle during a cylinder balance check #3 cylinder seems to be dead, #1 seems to be weak and #2 will kill the engine. #3 plug is always wet when removed. Swaped plugs, coils, no change. Compression test 95 on all cylinders. Remove carb disassemble and clean, check float adjustment etc., reassemble --same same. Disabled oil pump and mixed oil 50:1 in can --same same. The thing is it seems to idle some what smooth, no great clouds of smoke, and be somewhat responsive. Is this a normal thing on 3 cylinder engines?? Thanks for any input
    95lbs compression is a little low but ok. Try running Combustion Chamber cleaner or Sea Foam through engine to clean carbon from rings and piston's.
      Runaway,
      Don't give up yet - I know working on these outboards can be frustrating at times .
      What is the exact model for your Yamaha? I think there are three pulser coils for your motor.
      Sounds like you have a spark problem at low rpm, and I'm gonna guess maybe a faulty pulser coil or perhaps a bad CDI.
      Ken K
        Thanks for the replies. The model is a 40shjd.
          Runaway,
          "40shjd" - the d stands for year 2005, but I can't find your motor in the online catalog .
          Check the model again - and year. Look in the online catalog above.
          Ken K
            can be the same as i had on my 30 hp-
            cylinder sleeve turned 90 degrees and blocking intake/exhaust port. Take out the plugs, turn the piston to its lowest point and use a piece of wire to probe if the ports are in the same position as in the other cylinders.
            If not, you can start looking for another engine..
