Good afternoon. I am working on a 2002 F50TLRA 50HP 4 stroke outboard. Original owner - carbs have never been messed with. I'm in the process of cleaning all the carbs. I noticed that all 4 carbs have different main jets. #1 carb = 124, #2 carb = 126, #3 carb = 116, and #4 carb = 114. The factory parts diagram does list these 4 main jets - but it does not specify which carb gets which main jet. Is this correct? Just making sure - I'm used to all the main jets being the same. Thanks for the help, Wes
2002 F50TLRA Main jets not the same?
Originally posted by rejesterdhm. Based on this diagram..
https://www.yamahaonlineparts.com/oe...02/CARBURETOR/
..from top-to-bottom, the order is 124, 126, 116, 114. I've worked on the carbs for a 2001 F50TR, and they all looked the same to me. But I cleaned one at a time, so I didn't mix/match any of the jets between carbs.. so I can't be sure if they're all exactly the same.
The parts list at BOAT.NET (the SPONSER HERE) shows the different jets available, period: https://www.boats.net/catalog/yamaha...lra/carburetor
How do the spark plugs look, pretty much the same?
I wouldn't think the jets would be different in the same engine (especially water cooled). Perhaps assembled on a late Friday...
As you noted, the main jet, part #17 is available in different sizes.
Unless you have a plug burning much different than another, fouling, etc, I'd leave them where they were..Last edited by TownsendsFJR1300; 05-14-2019, 06:37 PM.Scott
Originally posted by wesleyjames View PostGood afternoon. I am working on a 2002 F50TLRA 50HP 4 stroke outboard. Original owner - carbs have never been messed with. I'm in the process of cleaning all the carbs. I noticed that all 4 carbs have different main jets. #1 carb = 124, #2 carb = 126, #3 carb = 116, and #4 carb = 114. The factory parts diagram does list these 4 main jets - but it does not specify which carb gets which main jet. Is this correct? Just making sure - I'm used to all the main jets being the same. Thanks for the help, Wes
Curious, how do you know that order (4, 3, 1, 2) ?
(and part #17, not 18 should be highlighted)
Have you no sense of decency man?Last edited by pstephens46; 05-14-2019, 07:29 PM.
Originally posted by TownsendsFJR1300 View PostCurious, how do you know that order (4, 3, 1, 2) ?
The order is 4, 3, 1, 2 because that is the way that Yamaha listed them in their parts catalog. Does Yamaha have it correct? Don't know.
I can only presume that during development they measured the air/fuel ratio and determined that the different carburetors required different main jets to get the air/fuel ratios the same.
Thanks for all the responses. Spark plugs looked OK. Nothing stood out to me. I was just taken back by the different main jets on all each cylinder. The parts list I was looking at didn't list the cylinders next to the respective main jet. I was just ruling out that this engine wasn't assembled Friday before a holiday or something!
Here is what the factory parts catalog indicates. Straight from Yamaha. I added the circles and the arrows by the way.
Originally posted by boscoe99 View PostDid you notice that the float bowls all have a different part number and position as well? I hope so.
I have a 2003 F50TLRB with the same carburetor setup.
i'm curios if you made and change or mod to the carb?
i notice 2003 F60 TLRB model. all 4 carburetor main jet size is #124.
has anyone ever swap them? or just install the F60 carburetor on to the F50? i think they are the same size?
some a hole drilled the main jets on my C40 before I got ahold of it
took me over a year to figure out why I had a high speed miss.
main jets had the proper numbers in the proper places.
finally bought all new jets to fix.
do not try re-engineering things.
i
ÂÂ
