Tach not reading RPM
  • Tach not reading RPM
    1999 130 saltwater series tach not reading right . Does not read rpm and sending mixed signals to overheat and low oil lights !!! I could use any help maybe bad ground???
    A bad ground or bad (corroded) battery cables will cause all kinds of issues.
    I would start at the battery, remove/inspect/CLEAN terminals/cable ends. Don't just look at the connection, remove it, make sure its clean, some di-lectric grease, re-install. Same procedure for ALL the battery cables up to the engine.
    If there's a a Perko type on/off/both switch, over time, they tend to loose their connection. If in doubt, by pass it..
    Check the basic's first, please report back what you find..
    Good luck..
